I've been using mp3tag for ages, but am only now discovering it's true power. (Was pushed into action by annoying mp3 players with infuriating tag reading limitations).
Anyway, I haven't been able to figure out how to effect the following Format Value...if anyone can help me I'd greatly Appreciate it.
Here's what I'm after:
If Artist tag is "Various Artists" AND Album is "Singles" then change Artist tag to "Singles"
If the conditions are not met then leave Artist tag unchanged, or if that is impossible, replacing Artist tag with %albumartist% would have the same effect.
This request, isn't it a one shot?
Once you have set the filter, select all filtered files, open the dialog "Extended Tags...", change the value of the tag-field ARTIST to "Singles", press OK, that's all and ready.
Why do you expect the same case to coming up in the future again?
