Hello,
This is my first post, I am really enjoying using MP3Tag and expect to donate as I think the program is very useful to my daily computing, but can anyone help with with a small problem I am having first that limits my enjoyment?
When I first opened MP3tag for the first run and selected an MP3 folder, I saw the 'default' column-list was showing.
This has column fields such as Filename, Path, Tag, Title, Artist, Track etc etc
I only wanted to use a few particular columns, so when I right-clicked on the title of any of these default columns, I got the right-click option to select 'customize columns' - which I did and ticked just the ones I wanted (in my case, just Filename, Title, Album and Track).
It then showed just my selected fields and I was able to edit my tags.
However...when I restarted the program I lost all my settings, and this is where I am having problems.
When I restart the program, all the default fields are back there in the columns - as if I never customized them - eg all the one I unticked are back.
To make things worse, every time I restart the program, it doubles and duplicates the column fields! so that after just a few restarts I can have hundreds of duplicates of 'Filename', 'Tag' etc showing in the box to customize the column fields. After a good few restarts the program has thousands of them and grinds to a halt. No matter if I delete all the dupe's, they keep coming back twice as many each time!
Can anyone advise me what I am doing wrong?
I need just a basic set of column fields and I need it so they don't keep reappearing and doubling each time I restart.
For info, this happens even after I reinstalled XP fresh, and also a fresh install of Windows 7 RC.
I have ZoneAlarm Extreme running, nothing else from a default install of Windows.
But lets see, if we can sort this out.
