help nuub
just started using this, been trying rename multiple .mp3s
'songtitle [my best tunes].mp3' how would i remove [my best tunes] part ?
Select your files, press Alt+3 (that's Convert > Filename - Filename)
In the first field enter
%1 [%2]
in the second
%1
