It seems to me, that actions are very helpful. I practised that for simple string operations with good success.
Is it possible to automatize the following two steps into an action?:
- Sort Files according to Tracknumber
- Convert Textfile to tag using a given format string (like the manual action)
I am using the most current version of MP3TAG.
Regards and many thanks in advance,
-Richard
