Using Mp3tag v2.46a on Win XP Pro SP3
The only link under the Help option that is working is "Check for new version ..." and pressing F1 does nothing. Because I often refer to Help files, I would like to fix this.
Also, can anyone suggest a good tutorial (English)?
Thanks
EdP
