help please, probably very obvious...
#1
I'm trying to put my own code together to pull info & images from juno.co.uk (any help appreciated at this point)
I've been looking at how the discogs one works but i don't understand this;
how
findline "<a href=""
findinline "<a href=""
sayuntil """
say "|"
will produce '/release/9130' from this;
Exit Planet Dust
the syntax looks wrong, it shouldn't be able to find <a href=" as it doesn't appear anywhere, yet it works.
This is probably something really obvious but could someone explain it?
Cheers.
#2
\ is an escape sign because " mark start and end of a string so when you search for a " in the html code you need to write "
#3
thanks for the quick reply, thought it might be something obviously simple..
cheers
