Help removing question marks and other characters from title
I am trying to rename my mp3 files and some of them have question marks and other characters at the end of the title. For example right now it is showing as what's really happening?. How do I remove the question mark and other characters?
Thanks
You can remove single characters with an action of the type "Replace" for TITLE
Search string: ?
Replace string:
(leave empty)
If you want to remove these characters to create valid filenames, you can simply use the function Convert>Tag - Filename. This produces valid filenames and leaves out invalid characters.
Also, there is the scripting function $validate() which you can use in format strings.
I am new to this, I'm not sure how I would create this action.
Could you please explain
Please check out the "How tos" on how to create a new action:
Once you got that action, select all the files that should get treated and apply it.
