Help to remove Track tags
Greetings,
I have a mixed music library (mp3 & flac) of 33,000 songs. About 1/3 has track tags which I am unable to figure a way to remove them using mp3tag v3.17 running in Windows 10 v. 22h2. Any idea to achieve this is greatly appreciated.
TT.
Load the files
Select the files
Go to the tag panel and the field for TRACK
Select <remove> from the drop-down list of the field for TRACK.
Save the changes with either the button in the toolbar or Ctrl+S.
Wait until MP3tag has finished the task.
Done.
Understood and thanks for your help!
