here's what i'm trying to accomplish:
if %track% contains "-" then i want to copy %track% to %discnumber%
for example, many tracks are numbered like this:
1-01
1-02
1-03
etc...
any help would be greatly appreciated, i'm sure this is simple, i'm just having trouble figuring it out on my own. thanks
i seem to have accomplished it with with the following "guess value action"
Source format
%track%
Guessing pattern
%discnumber%-%track%
alternative methods to accomplish it still welcome
Do you really want to copy the whole of TRACK into DISCNUMBER? Or just the leading "1"?
Anyway: it would be easiest to apply a filter like
%track% HAS "-"
If you then want to split the field then an action of the type "Import tag-field (guess values)" for TRACK and the mask
would move the 1 (or any other number in front of the hyphen) to DISCNUMBER.
If you only want to copy then run a simple "Format tag-field" action for DISCNUMBER with the format string %track%
well, yes, just the leading "1", but for simplicity i figured i could clean it up after the copy using "replace with regular expression"
