I'd appreciate some help getting encoding to work for me on AMG.
I've modified Dano's amg-classical script (thanks!) to pick up tags such as composer, work, and movement. And that's working well.
But I must be using the [Encoding] statement incorrectly (or I don't understand what it does) as extended European characters in the iso-8859-1 pages are not rendering correctly either in the Web Sources Framework dialog or after the tags are applied in mp3tag.
mp3tag is configured to write ID3v2.4 utf-8 tags. The AMG pages are encoded as iso-8859-1. I've tried all three options for the [Encoding]= statement in my src file, but none provide me the correct rendering. If I copy and paste from the web page directly into mp3tag, the accented characters are correctly rendered.
Thanks for checking that out. Since your unmodified script didn't display correctly on my computer either, I changed my second language in the Control Panel Regional section to Hungarian from Hebrew and now it displays correctly.
Nevertheless, it seems to me that the [Encoding] statement might have provided the flexibilty to adjust the conversion without going into system settings. AFAIK no other program had been displaying ISO-8859-1 encoded information incorrectly.
