In THIS thread I receive help from ohrenkino and that script with two loops served me well until now.
The problem is that when I try to export from multiple folders at once, if some of the albums folder have sub-folders numbering the discs, the result that is written on the TXT file is just the name of that sub-folder. Some similar to this:
CD 1
track1
track2
track3
CD 2
track1
track2
track3
Another problem with the actual script is that when two albums folders have exactly the same sub-folder name (example: both have a Disc 1 sub-folder) the export result ignore the Disc 1 folder of the second one and just proceed writing the sub-folders with different numbers that do not exist on the first folder. I mean, suppose that 2 album folders have this structure:
Album A have "Disc 1" and "Disc 2" sub-folders.
Album B have "Disc 1", "Disc 2" and "Disc 3" sub-folders.
Using the actual script the TXT will have the tracks from the "Disc 1" and "Disc 2" sub-folders from Album A listed, but no from the Album B, Album B will only have the tracks listed starting from "Disc 3".
I'm searching for something that result on something similar to this:
Album Name
CD 1
track1
track2
track3
CD 2
track1
track2
track3
Anyone can give some advice or a answer to improve the previous script making it able to supply this need?
Thanks in advance for all help provided.
