I use iTunes as my music player (on Windows). iTunes has a “Work” tag that I populate. When I import my music library into mp3tag, things mostly work. The tag shows up in the main display and I can filter on it.
However when I try to export the data the “Work” tag does not show up. The output of the export does have a Work column, but it is always blank. Here is my export configuration:
$filename(txt,utf-16)Title$char(9)Artist$char(9)Album$char(9)Track$char(9)Year$char(9)Work$char(9)BPM
$loop(%\_filename_ext%)%title%$char(9)%artist%$char(9)%album%$char(9)%track%$char(9)%year%$char(9)%work%$char(9)%bpm%
$loopend()
Another odd thing is that I cannot add the Work tag to the Tag Panel. I don’t really care about the Tag Panel, but it may be a hint to solving this.
I hope someone can help.
