Help with Filename->Tag
I'm hoping someone could help me please. I have a whole bunch of filenames that I need to make tags from as the tags are empty. Here is an example file:
07.Saxon - Princess Of The Night.mp3
In case there is any confusion, Saxon is the artist, Princess of the Night the song title.
I've got everything set up nicely so that I can go Tag->Filename later to fix the filename, but getting the info into the tag is throwing me.
Thanks for any help you can give.
You can use the converter "Filename - Tag" and a format string like
%track%.%artist% - %title%
to get the info into the tag.
See also this post for more details on the feature:
Thanks, that worked perfectly.
I was all worried that was going to be a lot harder than it was. I will read the FAQ and try to figure out the next one before I bother anyone with it.
Thanks again and thanks for the great program. It has saved me so much time!
