Help with Filename to Tag
All my .mp3 files are labeled Artist-Title (Year). What script would I use to get them to list separately into the Artist, Title, and Year columns?
Convert filename to tag:
%artist%-%title% (%year%)
Thank you so much! Is there a tutorial somewhere that explains these things in layman's terms? I've tried to watch YouTube videos for the last 3 hours and nothing has addressed this.
I'm not sure if there is an easy tutorial: the key is that all tags are structured as %TAG% (informational fields such as the path and directory are structured at %_TAG%).
If your files are named consistently, then you can identify the various tags by exactly replicating that name, replacing the actual data with the %tag% identifiers.
For example, I name my files consistently as D:\Music\artist\date album\track. title - artist.mp3. I can replicate that structure to extract all kinds of data into the tags.
OK, I may be reaching out again. Appreciate the help!
There is the FAQs and HowTo section in this forum, for instance:
