Hello.
How can I do this the next:
I have in the tag the field "WWW ARTIST" and I want to format it to "WWWARTIST", but only if WWW ARTIST is not empty or missing.
I appreciate any help.
Cheers.
Action #1
Actiontype 5: Format value
Field: WWWARTIST
Formatstring: %WWW÷ARTIST%
Action #2
Actiontype 9: Remove fields
Fields to remove (semicolon separated): WWW÷ARTIST
Note: Replace each special ÷ character with one space character.
End Action Group 20110521.pepe murillo.WWWARTIST (2 Actions)
DD.20110521.1957.CEST
Yeah thanks, but as I say before, only do this 2 actions if the "WWW ARTIST" is not empty and exist.
I rely on the miraculous Mp3tag and assume, that this requested optimizing is done by Mp3tag internally ... well ... for action #1 of course ... action #2 will be executed, anyway.
Hmm ... is your intention ... to prevent overwriting resp. removing the possibly existing content in the tag-field WWWARTIST?
You didn't say that explicitly, but such situation would be the only reasonable background for your request, isn't it so?
Try this ...
Begin Action Group 20110521.pepe murillo.WWWARTIST.1Action #1
Field: WWWARTIST
Formatstring: $if2(%WWW÷ARTIST%,%WWWARTIST%)
Action #2
... or maybe this ...
Begin Action Group 20110521.pepe murillo.WWWARTIST.2Action #1
Actiontype 7: Import tag fields (guess values)
Source format: $if2(%WWW÷ARTIST%,%WWWARTIST%)===%DUMMY%
Guessing pattern: %WWWARTIST%===%WWW÷ARTIST%
End Action Group 20110521.pepe murillo.WWWARTIST (1) (1 Action)
DD.20110522.2013.CEST
I don't understand why this is so complicated. Mp3tag will never create empty fields (and if you set a field to a null string, it will be removed, not left empty). So it's simply:
Action type: Format value
Field: WWWARTIST
Format string: %www artist%
If I do this and the WWW ARTIST is empty or doesn't exist, the WWWARTIST (even if exist) just dissapear. I did the test already.
You failed to mention that WWWARTIST may already exist. You should state the problem completely. In the meantime, maybe you want:
Field: WWWARTIST
Format string: $if2(%www artist%,%wwwartist%)
Action #1
Field: WWWARTIST
THanks, this action do like I want it.
