I’d appreciate help on a reg-exp for the following.
The original album tag tag reads:
“Mozart: Piano Sonata in F major, KV 280 - III. Presto - Mitsuko Uchida – Philips 1990 ”
And I need to change it to:
“Mozart: Piano Sonata in F major, KV 280 - Mitsuko Uchida – Philips 1990”
The single string to be removed is variable in length, and will always be the first such string in a series separated by dashes. The string may contain non-alphameric characters like "." or "-".
Thanks in advance.
