First, Thanks to Dano for the following registry patch to add Mp3Tag to the context menu (right click menu) for all files:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT*\shell\Mp3Tag\Command]
@=""C:\\Program Files\\Mp3tag\\Mp3tag.exe" "%1""
The above works great to add back Mp3Tag to the context menu after I upgraded to Windows 7, but only seems to work when I select a single file. It does not seem to result in Mp3Tag appearing in the context menu when I select multiple files.
Anyone out there have suggestion sof what to add or alter to make this work for multiple file selections? Thanks!
