Hello, Florian, I wish you success.
I want to request a fix for a feature in MP3Tag, which I think many will call futile, but for me it's very, very useful.
It's about more accurate alphabetical sorting.
What currently happens: the program interprets whitespace as if it were a character before the letter "a" and before the number zero. The sorting routine should "ignore" the whitespace.
For example, the correct order would be:
ABEL
ABELHA
ABÓBORA
A CASA
A DATA
AREA
AEREO
ALFABETO
ALFA ZEMA
ALFAZILDA
But the program orders (incorrectly):
A CASA
A DATA
ABEL
ABELHA
ABÓBORA
AEREA
AEREO
ALFA ZEMA
ALFABETO
ALFAZILDA
This also interferes with auto-numbering.
Thank you very much in advance.
I don't think that Mp3tag sorts AREA to AEREA (but that's maybe just a typo?)
Notepad++, for example, sorts your lists in exactly the same way that you describe as 'incorrect'.
What other software can sort the words in your list the way you want?
You could use the scripting function $replace() to remove the space characters (and any other character of which you think that it leads to an incorrect order).
For Columny you could enter the $replace() function in the column property "Sort by", in a format string, you could use
$sort($replace(...))
What you call incorrect is the generally used sorting in software. It also is the same like in Windows Explorer.
There is software that uses lexicographic sorting, mostly library software, but even there are country-specific rules.
There is an easy workround. Create a new tag field, calling it %titlesort% or something similar. Do this by adding the new field to your column view. Then fill that field with the text variants that you want to sort on. So, using your example, TitleSort fields would include these values:
CASA ...
DATA ...
etc.
Instead of A CASA and A DATA, etc.
Then copy over the non-variant title entries into the new tags as they are.
Now you can sort all "correctly" on TitleSort in column view.
This workaround is widely used for fields like AlbumArtist (AlbumArtistSort) and Artist (ArtistSort).
Hello! Thanks for your interest in helping.
Friend, I'm still a novice in this system.
Could you give a more explicit, detailed example? What I want is to sort by %artist% and %title%, disregarding whitespace.
Dude, I understand your point.
Imagine a song called "The House" and another called "Theatre." In a playlist, which one do you think should appear first? In my humble opinion, it would be "Theatre" first and then "The House," since the letter "A" comes before the letter "H." But in the mp3 tag, "The House" appears first and then "Theatre."
Hi, my friend. Yes, most software works this way. But that's because the software understands whitespace as a letter that appears before any and all letters, symbols, etc.
The ASCII code for a space is 32, while for the letter "A" it is 65. If the code for a space were, for example, 255, the records with whitespace would be at the end of the file. As I mentioned before, mp3tag displays "The House" BEFORE "Theater" because, for it, the space comes before the letter "a," resulting in an incorrect classification.
Yes!
The dbfviewer 2002 software, which manages .dbf databases, has a modded version, which I requested from the author, that does this.
dbfmanager also does this. (Also at my request.)
(Both perfectly sort words with whitespace, as if the space didn't exist.) www.dbf2002.com and www.dbfmanager.com
