I am using Strchr function extensively.
I normally use it with other scripting functions to remove portion of text from title of the song.
For example I use following to remove any text/characters in 'title' tag beyond '-'.
$left(%title%,$add($strchr(%title%,-),-2))
So my title would become from abc - xyz to abc.
But if my title is like this abc (xyz) then I CAN NOT use the same scripting function as below
$left(%title%,$add($strchr(%title%,(),-2))
It gives me error. so I can not use ( (left bracket) as the separating character.
Any workaround to this?
Thanks for reading.
