Help with tag -> filename scripting
I want the following:
  1. 1 leading 0 if total tracks for album/folder < 100
2: 2 leading 0s if total tracks for album/foilder >= 100
how can I do it? Thank you.
Try the auto-numbering wizard Ctrl-K and tick "Leading zeros".
For more detailed help you would have to show us the tag data and the format string that you use in Convert>Tag-Filename.
