Hello ppl. N00b here, need a little help. Let's say I have a track with TITLE tag containing the following:
Ocean City Girl [Album In The Clear (Nettwerk)]
How do I extract data from it to get artist, title and album tags so that I get:
Title: Ocean City Girl
Album: In The Clear
Many thanks in advance.
Cheers,
Kindofblue
You create a new action set, add an "Import Tagfields" (or whatever that's called in English) action and use the following configuration:
Source format: %title%
Formatstring: %title% [%artist%]
If you want to remove the brackets, add a "Replace with regular expressions" action and replace \s*(.*) with nothing (leave the last field empty) in ARTIST.
dano
August 24, 2005, 8:20am
3
If the formatstring is %title% [%album% (%dummy%)]
it's done in one step.
Ah, right.
BTW, the action type is "Guess values".
Thanks guys. Worked nicely. I also added a Replace to get rid of "Album:" from the ALBUM tag.
OT: How do I rename my Actions? Can't seem to do it via double- or right-click.
Thank you guys for your patience.
BR,
kindofblue
dano
August 25, 2005, 5:48am
6
A "slow" double click. Like in Windows Explorer
Oh right. Silly me. Thanks Dano.
