I use WMP to play my files, because the sound doesn't come out as low as in stupid as a rock itunes, plus the interface is more pleasant.
I use itunes for its superior and way better tools to create automatic playlists that allows me to use an endless variety of criteria, which in WMP are simplistic at best.
Right now I have a problem to find a tag that exists in both WMP and itunes, that is appropriate for the task, and that will allow me to select tracks automatically in WMP that are not Easy listening/slow ballads.
For that, I tagged all tracks that I like and that are Easy listening in itunes, using the Subgenre = Easy (in WMP, this tag is called Subgenre instead, and in Mp3Tag it's called, Contentgrouping.)
Now, because stupid as a rock WMP doesn't allow me to create a playlist using "subgenre does not contain Easy", it only allows me to pick "Subgenre" Is or Is not or Contains, I'm in an impasse.
But the problem is that I've been adding more info under Tag Subgenre, which causes the Subgenre is not Easy to no longer work, for example, I now have tracks with Subgenre Easy\Picard, instead of simply East, so criterion Subgenre is not Easy will no longer work for that one.
So, if you were able to understand the catch 22 above, what I need to do is to find a tag X that exists in both itunes and WMP, so that I can populated it in itunes with Easy (X=Easy), and then use that to select tracks automatically in WMP.
To cut a long story short, do you know tags that exist in both WMP and itunes (for playlist creation), that I can use with that intent?
One such tag is Subgenre=Grouping=Contentgrouping, but that one is taken already.
