Hello, can anyone help me change my tracks from:
Artist - Songtitle ft. Artist2
to:
Artist ft. Artist2 - Songtitle
Thanks in advance.
to:
Thanks in advance.
see e.g. here: /t/19388/1
I can't really understand what to do from the examples
As the examples are pretty thorough I have hardly any idea where to start.
So you have to help me and tell me how far you've got.
E.g. are we talking about filenames or actual tag fields?
$regexp('Artist - Songtitle ft. Artist2','(.) - (.) ft. (.*)','$1 ft. $3 - $2')
I just need to tag my songs using my original filenames.
My first attempt was to use %artist% - %title% from convert > filename - tag
However now some songs with featuring artists were put in the title.
I want the featuring artists to go into the artist section.
Forgot to mention that some of my tracks have this format in their filename
Artist - songtitle ft. artist2 (remixname)
I guess that needs a different approach right? That would need to be:
Artist ft. artist2 - songtitle (remixname)
Please fill the tags first - mucking about with the filename makes it even more difficult.
It may be easiest if you move the "ft. artist" to a separate (user-defined) field first.
For "songtitle ft. artist2" use an action of the type "Guess value":
Source: %title%
Guessing pattern: %title% ft. %feat_artist%
Check the extended tags dialogue (Alt-T) and see that you now have a user-defined field "feat_artist"
For "songtitle ft. artist2 (remixname)" use this approach:
Action of the type "Guess value"
Source: $regexp(%title%,'(.) ft. (.) ((.*)','$1 $3__$2')
Guessing pattern: %title%__%feat_artist%
Now apply a filter with the expression:
%feat_artist% PRESENT
Select the files and apply an action of the type "Format value" for ARTIST
Format string: %artist% ft. %feat_artist%
If the result is OK, delete the field FEAT_ARTIST in the extended tags dialogue.
