hi guys,
i have just discovered this excellent App.
what i would like to know is is there a way i can drop a directory in and have the program automatically search/tag/rename?
at the moment it works ok but i have to.....
drop the directory in,
select all (by pressing CTRL+a can this be done auto too?)
click on the freedb icon, choose determine from the selected files, OK.
then when i get the results thru (sometimes numerous/select correct) i OK.
then it just renames the tags and not the filenames so i have to click on 'tag to filename'
what i would like to know is can any of this be simplified?
or are any of these features going to be implemented in a future build?
as i have stated above......but i will try and be clearer.....this is how in an ideal world it would work for me.
- Drag Folder into Mp3tag. (the mp3s are scanned and all are selected by default)
- i click on Freedb button. ( it searches as per my default setting of 'Determine from selected files....i choose the album most applicable and OK it.)
- The program then Automatically Tags and Renames the files.
Job Done.
thanks for your time and please do not think i am slagging this app off....i am just new to it.
thanks
KYUSS
