Hi how can I remove track number
Hi how can I remove or replace track number with artist name?? please! the tracks don't have tags
Untitled5|625x500
Don't you want to save that track number (and the other pieces of data that you find in the filename) in the tag fields?
Use Convert>Filename - Tag
Pattern: %track%. %title% @bY %artist%
(Check the preview if the pattern is right - perhaps I misread the @bY)
Then use Convert>Tag-Filename with
Format string: %artist% - %title%
No does't works :frowning: files don't have tag and i want to write artist on every track
Which is the artist?
Is it "Profu"?
Could you supply a copied and pasted plain text file name here in the forum? Then I could transform that into a pattern for the tag import.
Nicolae Guta is the artist i write into the Artist but I cant write the title on alll tracks
I think that the title is somewhere in the filename.
It could be that the following suits you better:
%track%. %title%
See if the preview is any better
yes it's work thank you again you are the best
Great, that it works
If you want to rename the files, use Convert>Tag-Filename (e.g.)
Is there tutorials of this program?? Is verry useful and I want to learn more ... Thanks again
Even though this sounds not very motivating: the online help starts with a basic introduction "First steps".
And there is the "FAQ" and the "HowTo" section in this forum with a lot of ready-made recipes to get the grasp of this program.
And then there is the forum where you can ask questions or even give advice.
Ok I understand it''s very useful this program :innocent: :innocent:
