Hello To All... I am newbie with the Mp3Tag and i would like you to help me sovle some problems...
I want to organise my songs and i dont know the way to transform them via the mp3tag...
All of my songs have the style : ( Avicii & Sebastien Drums 'My Feelings For You' )
(Adele - Set Fire To The Rain )
This style first the Artist and After the Title of the Song...
I want to tranform them to be like Artist : Avicii & Sebastian Drums
Title: My Fellings For You
and Artist: Adele
Title : Set Fie To The Rain
etc...etc...
PS: if it yould be possible i would like you to show me the way to make and the first letter of every world with capital letters....
Thnx For Your Time I Look Forward To have 1 Replay For Someone....
To handle both cases separately, it would be convenient to use the Mp3tag Filter with the following filter expressions. Case 1
( Adele - Set Fire To The Rain )
"%_FILENAME%" MATCHES "^\(\s*.+?\s*-\s*.+?\s*\)$"
Case 2
"%_FILENAME%" MATCHES "^\(\s*.+?\s*'.+?'\s*\)$"
Then, for each case, apply the converter "Filename - Tag".
But for each case with the corresponding Formatstring, which contains the proper tag-field mask for splitting the filename into the Artist and Title components.
Case 1
Formatstring:
( %ARTIST% - %TITLE% )
Case 2
Formatstring:
( %ARTIST% '%TITLE%' )
After this splitting procedure is done, then you can use the Mp3tag Action feature and set the casing for the tag-fields as you wish.
First take a ride through the Mp3tag help manual to learn where you can find all the basic informations like actions and functions for your work with Mp3tag.
