sorry for bumping such an old topic. i just wondered the same thing today and i haven't found the answer here on forums. is it possible to add a column that will show the vbr values? if not, would you consider adding the option to add this column to the future releases? or even better, display "VBR Vx" instead of just "VBR" in actual collumn? it would be pretty cool. thanks for reply.
