How do I contact a poster?
Specifically, LyricsLover.
Click on the poster's avatar icon and select "message" from the popup.
Just click on my L-Circle-Avatar then click on "Message"
New users with trust level 0 cannot contact other forum members directly via personal message.
You need to participate in the community for a while to be promoted to TL1 or post your question publicly.
Hello @Florian,
I noticed that it seems possible for us to communicate with level 0 members. From what I can see, I think it's possible for @LyricsLover to communicate with @musicollector.
So my question is: if I send a message to a level 0 member, will the system send my message to that member, or will it block my message from being sent?
Yes, exactly like that.
I had already tried clicking on the L, but it did not work. I gather I don’t have the reputation, even though I had engaged in a thread last year.
I just wanted to apologize to LyricsLover because the thread was automatically closed last June before I could respond to him. Just in case I appeared rude to LL. My thanks to those who courteously responded there, instead of lecturing me to read the manual. My father passed away that week, hence, I did not pursue the thread.
Thanks.
That's very kind of you. You really don't need to apologize for that. Everything is fine.
ThanK you. Appreciate that.
