How do I edit preloaded genre list
I cannot find this question/answer although I'm sure it's here somewhere.
How do I edit the pre-defined genres in the dropdown. There are some in there that I will never, ever use (anime, bhangra, etc). And I don't want to see those unnecessary ones.
Thanks in advance for your answer.
see here for a discussion about the standard list for genres
you can add user-defined genres, see Tools>Options>Genres
You can set whether you only want to see the user-defined ones.
Perfect- thank you for your help
