How do I get rid of ID3v1 tags?
Using 2.14f (i.e. dev. version)
In File>Options>tags>mpeg, I have
Read: ID3v2
Write: APEv2
Remove: ID3v1
I thought that if I would select a file and save it, it would remove ID3v1, but it doesn't. What do I do wrong?
  • when I click on the "Logfile display" icon, I get a "Replace" window. If I cancel, it comes back again. If I cancel again, the logfiles appears. I guess it's a bug.
Arnaud,
your settings are right, but you have to use the fuction File, Remove Tag to remove tags of the type specified.
Thank you for the hint with the replace dialog - this was some early testing code of the new action framework :wink: It's fixed with the current development build.
With best regards,
~ Florian
Oh, ok :slight_smile:
I thought that it would completely remove all tags.
Bug fixed indeed, thanks
