Dear Mp3tag friends,
I love Mp3tag!
I need to know how to put a leading "0" in the filename numbers. For example, to convert "Chapter 1.mp3" into "Chapter 01.mp3".
In my situation, I cannot use the Track Number as the source of the number for the filename.
Many thanks for your help!
Best regards,
Chris Lascelles
Does this work?
Action type: Replace with regular expression
Field: _FILENAME
Regular expression: (\s)(\d)(..*)
Replace matches with: $1$num($2,2)$3
[ ] case-sensitive comparison
Hey Sebastian,
It works perfectly! Thank you so much!!!
Best regards,
Chris Lascelles
A simple way to do that is Tag - Filename change the "%track%" to "$num(%track%,2)". Know you can change it in the same step as you create the file name. There also the autonumbering wizard that will do this.
Marc
