How do i remove specific text "-"
so after reading a bunch of prior support documents. i am left with no working answer to this quagmire.
in the %TITLE% field
i want to replace " - " | note the space before and after
with " " | note that it is replaced with a single space
i have tried
$replace(%title%," - "," " )
$replace(%title%, - , )
both with no accurate result
the first one removed the spaces in the title around the -, but not the -
im pretty sure i am close, but missing it...
thank you :slight_smile:
Please ensure, that the - is really the minus you expect.
Just copy & paste your hyphen directly from your TITLE for example to the input box on this website:
and press Identify.
The usual minus will be identified as
U+002D : HYPHEN-MINUS {hyphen, dash; minus sign}
However, there are many variations:
so how do i format the string to replace the hyphen/minus sign?
can i use the unicode?
$replace(%title%, U+002D , )
what about the leading and trailing spaces?
-- that did not work
What answer does the website give you?
If it is a "normal" hyphen, you can use
this is space hyphen space after the first comma
and after the second comma (= replace with):
space
You can easily test it with "Convert Tag - Tag" first and see the preview:
Please be aware that this will replace all instances of your search string with your replacement string, not just the first one.
If you really like to replace an identified hex value for special characters (like U+FF0D : FULLWIDTH HYPHEN-MINUS), you could use $regexp and regular expressions.
$regexp(%TITLE%, \x{FF0D} , )
or for your above example with the usual hyphen:
$regexp(%TITLE%, \x{002D} , )
which is
space backslash x "left curly bracket" 002D "right curly bracket" space
replaced with a space
the latter worked perfectly - thank you again!
