I want to replace the third character in _Filename with ' '.
How do I do it?
Thanks a lot,
David
How do I do it?
Thanks a lot,
David
create a format tag field action:
format %_filename% with
$left(%_filename%,2) $mid(%_filename%,3,$len(%_filename%))
(the blank between the 2 $-commands is your inserted blank).
Thanks for your reply.
Maybe I did something wrong, but that just added a blank to the left of the third character.
i.e. if filename is 12a4, it's now 12 a4.
Here's what I did:
Is that what you meant?
Thanks,
David
Basically that's right.
Now you may experiment a little with the second part and move the starting point of the "middle string" more to the right:
Format string: $left(%_filename%,2) $mid(%_filename%,4,$len(%_filename%))
I'm not really sure I understand but it works ![]()
Thanks a lot! ![]()
