How do I stop apostrophes being changed to underscores?
Hi there,
I’m using the Convert > Tag - Filename option to add the Album Artist and Album as folders before the track and title.
%albumartist%\%album%\$num(%track%,2) %title%
But when the album artist’s name has an apostrophe (“Sharon O’Neill”), the apostrophe gets replaced by an underscore.
Is ther any way of stopping this from happening?
I just tried
as part of a filename and the character between O and N was kept:
But:
that character is no apostrophe:
with an apostrophe it would look like this:
Invalid characters for filenames usually just get skipped, e.g. like this using a quotation mark:
You could use a $replace() around your format string and define the replacement character as you like.
Something like this, where x is the replacement for your ’
$replace(%albumartist%\%album%\$num(%track%,2) %title%,'’',x)
But there is no need for a replacement. The character in the example ist a valid sign for folders and filenames and it does not ge replaced by an underscore here.
The OP says
I can't see too why an apostrophe (or similar looking character) should be replaced by an underscore with Convert Tag -> Filename.
$replace would be just one way to solve such a special character as the OP see it.
For me it looks as if there is already a not mentioned $replace function involved.
