i need please your help about an function i hope its work.
i DL many sounds but unfortunatly they put like in my case in 1200 files "Album version" just after the titles of those sounds. or "remaster" or "LP version" or "Explicit"
i want to search those words in the Tags of mp3 and flac files i have and delete them automaticaly without doing manualy those 1200 files.
can you please tell me if your software can do that ? or if you have another solution ?
Filter for the words that you do not want, one after the other, e.g. %title% HAS Album version
Select the files.
Then create an action (perhaps a quick one, I don't know how often you need to do this bulk cleanup) of the type "Replace" for TITLE
Search string: Album version
Replace string:
(leave empty)
Click OK.
Please take care of space characters in front or behind the search words - it may be that you want to remove them also.
Do something comparable with the other words that you want to remove.
So my initial suggestion is still valid:
Action of the type "Replace" for TITLE
Search string: _Album version
(where the _ is the leading space. When you type in the search string, use the space character, I only had to use the underscore here in the forum as the editor usually swallows the space character and you would not see it properly)
Replace string:
(leave empty)
Once you have cleaned up the tags, use Converter >Tag-Filename and rewrite the filename, probably with %title%
