I was wondering how you would do this,
15goodsong -> 15. Good Song or 15. goodsong
the goal is to get the . after the # so if I have,
4 The Best Song Ever -> 4. The Best Song Ever
This is for the Filename field (edit)
Thanks!
Thanks!
Create an action of the type "Replace with regular expression" for the field.
Search string: ^(\d+)
Replace string: $1._
(where the _ is a blank - of )
If we are talking about the filename, you should use the function Convert>Tag-Filename
Also, it could be necessary to remove double-blanks afterwards.
What do you mean by "tracktitle", ...
does it be the tagfield TITLE, ...
or does it be the pseudo tagfield _FILENAME?
Why don't you create the target string fresh from the TRACK number and TITLE string?
DD.20170311.1950.CET
This worked, thanks I love you!
