How to add a name in front of the title tag
heiiii....am a new bee.....
my problem is.....
i want to add my name in front of all the tags including filename,titile,artist,album,composer,comment etc multiple mp3 files ....
what action can do dis??
First please read the FAQ here for all the newbie Q and A.
Not sure why you would need to do this for so many tags but,
An example action for your needs is:
Action type: Format value
Field: TITLE
Format string: rpsh90 %title%
You will need to create actions in the same action group for the rest of your tags: filename, artist, album, composer, comment etc.
In case you run the action twice place this below the action groups you just created.
Action type: Replace
Field: TAG
Original: rpsh90 rpsh90 (_ represents 1 whitespace character)
Replace with: rpsh90_ (_ represents 1 whitespace character)
[ ] only as whole word
[ ] case-sensitive comparison
He means %title%
Field: TITLE
typo... thanks for getting my back :] Above post edited.
