hello,
using search i can't seem to find out how to add rating tags to my files. can anyone point me to where i can find step by step instruction on adding a rating tag to my music files....and how to view the rating as one of my columns.
thanks for the help!
i looked at the help files (before and after) i posted and i don't see this info in "help> Configuration>tags". what am i missing? also after adding the column "%rating wmp%" i see the column, but when i add a value for a track such as "4" or "****" it does not save to the column (in other words the column remains empty).
You are missing the right page: /help/main_tags.html ("Names and mapping of ID3v2/WMA/MP4 tag fields")
And while you are at it: please check if you only read the tag or also rewrite it. So fill in the name, the value with the variable %rating wmp% and also the field with %rating wmp%.
And if that still does not work, we will have to have a look at the type of tags you have in your files - the classic foe is APE. If you have APE tags remove them first. Otherwise no MP3 tags will be stored
thanks that did it. i didn't have the value set. can anyone tell me the difference between %Rating MM% & %rating wmp% ? and which might be a better option or most compatable? (i'm using wmp 11).
