Hello I have just downloaded MP3Tag to make life easier cataloging my Cd's. I have a lot of Cd's which are compilations and have artists missing, sometimes have tracks, sometimes the album or just some piece information.
Is there a way I can upload each which is now a MP3 file and auto tag each track?
I am not technical so a step by step instructions would be great if possible.
This depends an awful lot on the already available data.
MP3tag only uses the tag data and leaves the audio part alone. So MP3tag cannot "guess" which audio piece it currently handles.
There are converter functions that retrieve information from the path and/or the filename and there are web source scripts.
Whether you find the correct information there I cannot say.
It looks like you're trying to auto-tag the data for CD2 of a release named "Country Legends". I'd try using the MusicBrainz tag source from the Tag Sources menu for that.
Did you see the file I attached at the beginning of this conversation that is the sort of information I have ended up with. When Winamp was alive you could upload mp3's and send them to auto tag and would come up with best selections for the track or album. I was hoping MP3 Tag would do the same thing? Or have i misunderstood?
I think you are looking for a software that can add tags to your music after analyzing the music part of mp3. Have a look at software like "MusicBrainz Picard".
MP3Tag can only help you in exchanging informations from the filenames, directories and websources to fill your tags.
That's right. But also MB Picard can only "identify" music which was previously analyzed, the acoustic fingerprint uploaded and the track(s) joined with all the additional metadata in MusicBrainz.
