I have just started using Mp3tag and it seens to be a great software, but I haven´t realized how to batch add tags.
I want to add the ENCODEDBY tag. I use it to keep track of which encoder/version was used on creating the files.
TIA
TIA
Select the files and choose View, Tags.... Then add the ENCODEDBY tag field using the new field button and press OK.
Best regards,
~ Florian
Great!
Thanks a lot! It's going to be very useful.
Best regards!!
