Hi all!
I'm trying to batch replace all instances of \\ in the Artist field with ~
I see how to batch replace characters generally using Convert Tag - Tag
eg. $replace(%artist%,&,~) replaces & with ~ in the Ariist field,
but trying to replace \\ in the same way just results in the \ being removed along with all text after it.
Filtering the files shown with %artist% HAS \\ shows no files.
Is there a way to sort this out?
See e.g. this thread:
or use the search function and "double backslash" as search words.
Will do. Thanks for the input!
All info I needed was there. Job done! Thanks again
