How to clear Tag-Filename history
How can I clear all the old variants of Tag-Filename history so I can just have the 2-3 that I use most often?
Hello and welcome!
You can use Shift+Del to remove the currently selected format string from the list.
Or choose one of the remove options from the contextual menu that appears when you click the :arrow_forward: button next to the format string field.
We also have a search here, which often brings up existing answers to current questions.
I have never had to use the forum before so I was not sure how to search. Thanks for the quick response.
