How to copy cover art jpg when using tag to folder?
I managed to use tag to filename to move some flac files to a new folder structure. But I can't find a way to move the folder.jpg in the old folder to the new one at the same time.
Is there a way of doing this automatically when using tag to folder?
If you want to move the whole contents of a folder incl. normally unsupported files to a new location, do not rename the single files but rename the whole folder.
Use Convert>Tag-Tag for _DIRECTORY
Format string:
best an absolute path - leave out the bit that renames the files.
Once the folder has been moved to the new location, rename the files so that they stay inside the new folder (e.g. leave out the path part of the new name).
