I need to replace part of the Album tag with part of the Title Tag. How can I do this?
Using the Replace with regular expression I don't appear to be able to reference any field other than the one to be changed. I can locate both fragments with regular expressions.
You can do this in different ways, e. g. using a third temporary tagfield.
One possible solution could be using this scheme.
With ALBUM = "A B C" and TITLE = "D E F" you will get "ALBUM = "A E C".
Actiontype 5: Format tag field Field: ALBUM Formatstring: $regexp(%ALBUM%,(.) (.) (.),$1 $regexp(%TITLE%,(.) (.) (.),$2) $3)
