Is there any way to apply a regular expression to one field, and then use the results of that regular expression (through parenthesized sub-expressions) as changes to be made in another field?
For example, let's say I have tracks titles that have:
My Title (Track 1)
My Title 2 (Track 2)
My Title 3 (Track 90)
And I have a regex:
^[^(]*\(Track ([0-9]*)\)$
And I want to set the value for the TRACK field to '\1' from the above expression as applied to the TITLE field.
Is there a way I can do this? Also, is there a way to extract values from MULTIPLE fields to use in modifying a target field?
You can copy content from one tag to another tag, e. g.
Actiongroup: Copy content from one tagfield to another tagfield
Action #1 Actiontype 5: Format tag field Field: TAG_2 Formatstring: %TAG_1%
Well, that is a related thing, but it's not extracting content elements from one tag and transforming a second field based on them.
Say I had one field that had "ABC DEF 123" in it, and another field that had "XYZ HAHAHA 999", and I wanted to copy the digits at the end of the 2nd field and replace the 1st field's digits with them. That kind of thing is not doable with mp3tag, correct?
Thanks, D -- I'll give those ideas a try -- I appreciate the thought you put into it.
Do you happen to know if there is a tagging program that supports this kind of really complex
transformations with regular expressions built in, so that you needn't come up with
a strategy to do this based on multiple steps or intermediary tags?
