Hello everyone!
I have set up custom fields and don't know if I am doing things correctly. My goal is to populate these fields in MP3Tag and hopefully be able to map them to new fields that may come to itunes or others in the future. That way I can enter the data now and just map the fields in on swoop later.
The way I have done this is by going to the Columns and creating a new column through "Customize Columns". I set up the name, eg "Genre2" and assign %genre2% to the value and the field.
I can also do this with the tag panel. I must be doing something wrong, because when I try to use the "Convert" tool "tag>Tag" the fields don't show up. I know I must have done it a different way because I do see a genre 7 in the extended fields, but no genre2, genre3 and so forth. I have tried to read on this but cannot figure out what I did differently with "genre 7" other than it has a space in its name instead of "genre7".
If someone can explain to me how to do this properly or point me to a link I may have missed while searching here. I would sincerely appreciate it.
Thanks!
