I can edit Album Artist individually but I have failed to get multiple selected files to accept the same Album Artist using copy and paste.
Is this by design?
Using version 2.75
Ian
Is this by design?
Using version 2.75
Ian
More or less yes - but: select the files that should get the same data.
Enter the data in the tag panel (here Album Artist)
Press Ctrl-S to save the modification.
Alternatively, if you do not find the field in the tag-panel, use the dialogue "Extended tags" and enter the data there and save the modifications by clicking OK until all dialogues are closed.
Your first suggestion worked.
Many thanks!
Ian
