using mp3tag 2.52. i would like to delete the entries in fields like composer, comment, genre. and albumartist.is there any way to delete the entries by an action ? how can i delete the entries in multiple fields in a single click? thanks. have a nice day.
Yes. Use a 'Remove fields' action with field names separated by semi-colons.
thanks for the suggestion. but
I tried the following.
new action---remove fields"Album Artist;Genre;Composer;Comment"
all field entries except album artist was removed. what happened with the first field? did i make a mistake?
yes it works when album artist is entered without a space. it should be entered as albumartist. then only it will work. thanks once again to Johnson for the suggestion.
You can check View > Extended tags to get the right tag names.
