How to disable Quick Pick ?
Can one disable this? I found no corresponding setting in the options.
Sorry, but I am using MP3tag rather seldom and I hate to have yet another tray utility (I already have too many and they slow down my system, so I try to keep these at a minimum...).
Michael
You can remove it from windows autostart and on the next Mp3tag installation don't install it.
You can remove it from the strat up menu. In windows XP
C:\Documents and Settings**(logon name)\Start Menu\Programs\Startup
