When you try to remove a tag from a read-only file, you get a warning.
Can those warnings be disabled?
See the changelog:
[2015-07-08] CHG: renaming files marked as read-only does not require removing of read-only flag anymore.
For all other operations I would assume: remove the read-only status.
Here's how you can replicate the thread question.
- Right click on mp3 file and CHECK: Read Only > OK
- Open the folder containing this file in mp3tag
- Right click on it inside mp3tag > Remove tag > YES
NOW
YOU GET
File "E:\1\x.mp3" is read-only.
Shall Mp3tag disable the write protection of this and
any following read-only files?
How can that prompt be disabled to give mp3tag a permanent YES so it does not ask to disable read-only every time.
I don't think that there is an option in MP3tag.
So the only way would be: remove read-only flag prior to processing.
